STP state sync events - Multicast flooding
Hi all,
Debugging the STP state sync events on a Cisco 3560 running 12.2(55)SE1 through the following command:
debug spanning-tree synchronization
Every 2 minutes I get the following messages:
May  6 10:13:14: STP sync:  Send ALL port data to all other switches...
May  6 10:13:14: STP sync:  NULL sync_data -- nothing to send
May  6 10:15:14: STP sync:  Send ALL port data to all other switches...
May  6 10:15:14: STP sync:  NULL sync_data -- nothing to send
May  6 10:17:14: STP sync:  Send ALL port data to all other switches...
May  6 10:17:14: STP sync:  NULL sync_data -- nothing to send
May  6 10:19:14: STP sync:  Send ALL port data to all other switches...
May  6 10:19:14: STP sync:  NULL sync_data -- nothing to send
May  6 10:21:14: STP sync:  Send ALL port data to all other switches...
May  6 10:21:14: STP sync:  NULL sync_data -- nothing to send
May  6 10:23:14: STP sync:  Send ALL port data to all other switches...
May  6 10:23:14: STP sync:  NULL sync_data -- nothing to send
May  6 10:25:14: STP sync:  Send ALL port data to all other switches...
May  6 10:25:14: STP sync:  NULL sync_data -- nothing to send
Could anyone explain what does  "Send ALL port data to all other switches..." mean?  Can I disable the STP synchronization protocol?
As I'm running IGMP snooping on that switch, every time I receive the messages above, these are interpretated as a TCN spanning-tree event and the multicast traffic is flooded to all the ports. In order to avoid that, I had to disable the multicast flooding on the uplink interface:
no ip igmp snooping tcn flood
Is it a common procedure or just a bug?
Thanks and regards,
Vincenzo
Giuseppe Larosa
Hello Vincenzo,
this looks like a bug in 802.1W synchronization is performed when there is a topology change as a wave of STP handshakes
every 2 minutes is too regular to be true
do RSTP handshake sending port role and state to each switch neighbor
to reduce sync activity you should configure edge ports where no switch is expected with spanning-tree portfast but that's all
Hope to help
Giuseppe
