Strange Case - Port numbering on the Catalyst switch WS-C3560CX-12PD-S
Hannibal
Hi Community, the best of the internet
Let me ask the following query:
We are going to configure a switch for one of our remote offices. It is the first time that we have acquired a Cisco switch as small as the WS-C3560CX-12PD-S model.
The technical specifications are as follows:
  1. Uplink Interfaces: 2 x 1G copper plus 2 x 10G SFP+
  2. Ports: 12 x 10/100/1000 Gigabit Ethernet
  3. PoE Output Ports: 12 PoE+
  4. Other ...
  5. I have inserted the picture of the front pannel so you can see that.
Right now we are a bit surprised because with the show running command, two additional ports appear (interface GigabitEthernet1/0/15 and interface GigabitEthernet1/0/16) which we cannot match physically.
We have inserted on interface TenGigabitEthernet1/0/1 one SFP or GIBIC of 1-Giga of bandwidth.
Please, someone from the community has had this experience or can send a Cisco link to the explanation??
switch#sh run
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface TenGigabitEthernet1/0/2
Thanks in advance Community, the best of the internet..
Hann.
Hello
correct
Kind Regards
Paul
7 Replies 7
Hello
They’ll will relate to SFP insertion type on port 1/2 (gig1/015, gig1/0/16) be it either copper or fibre.
Kind Regards
Paul
Hi Paul
Thank you very much!!
This means that we must configure the port interface GigabitEthernet1/0/15 (logical) instead of port interface TenGigabitEthernet1/0/1 (physical) where the GBIC module (-Giga) is inserted?
Both interfaces number of interfaces appear in the configuration menu.
Thanks in advance
Hann
Hello
Correct.
Kind Regards
Paul
Leo Laohoo
Those two SFP ports can support SFP (1 Gbps) and SFP+ (10 Gbps).
Hi Leo,
Thank you very much for your reply...
Now I understand that if I insert a SFP (1GB), I must configure the interface GigabitEthernet1/0/15 or 1/0/16  instead of the interface TenGigabitEthernet1/0/1
And if I insert a SFP+ (10GB), then we must configure the interface TenGigabitEthernet1/0/1 or 1/0/2 instead of interface GigabitEthernet1/0/15 or 1/0/16. It isRight ???
Thanks in advance...
and kind regards
Hann
Hello
correct
Kind Regards
Paul
Thanks Paul..
Hann
