Strange Default IP 2960-X switch
Azuriste
Hello ,
as i have read , the Default Ip address of the 2960-X switch is 10.0.0.1 , but for mine is 10.0.2.1 , this is strange because i have the same model purchased from the same vendor and they have different default IP, is't normal ?
Second thing , so when i give a new IP to this switch and after saving the configuration , the switch can't take this new IP.what could be the problem Please ?
Regard
Reza Sharifi
It could be that you have to delete the existing one before you can add a new one.
For a new switch, you may want to use the console to make this change so, you don't get locked out.
