05-05-2010 10:54 AM - edited 03-06-2019 10:56 AM
I have a 3750 with 20 users
and that 3750 is connected directly to 2960. Every things works well
except my 2960 cant reach to my SNMP server which is directly connected to 3750.
The 2960 has a default route of 3750, & the clients connected to 2960 can reach to SNMP server but not the physical switch it self.
05-05-2010 11:11 AM
Is the 2960 L3 SVI in the same vlan as the SNMP server. If not some things to check -
1) No access-list on L3 SVI for 2960 on the 3750
2) SNMP server has correct default-gateway
3) can you ping the snmp server from the 2960
4) if you can't can you ping any client in the SNMP server vlan from the 2960
Jon
05-06-2010 09:47 AM
Jon
Its Not
There isnt any
It can reach to the machines on the management VLAN connected through 2960
I cant ping
Yes i can ping rest of the machines
05-05-2010 10:59 PM
What is the ip address given to 2960 switch is that of the management vlan or in the same production vlan where your server are connected.
Ganesh.H
05-06-2010 09:44 AM
2960 have a management vlan IP, how ever i have a a default route on 3750 to the production vlan. Also switch can reach to all other production servers except the SNMP
