Sub internface shutdown in Frame Relay point to point in GNS3
Wilson Kwok
Hello
Please take a look on GNS3 file in attached, I'm sure already configured both routers s1/0 is no shut, but still status down, please help.
19 Replies 19
Please see attached file.
Sorry, I don't understand what you mean.
I removed 241 240 in FR, both router still can ping 172.16.228.x
if you changed the FR switch config without telling us it indeed was going to be hard to troubleshoot for you.
Have you still got 2 routers only linked to one FR switch ? if so and if the routersconfigs are still valid then you should put the correct DLCI-port entries on the FR switch(you only have ports 1 and 2 with connected routers on the FR switch.
Alain
OK now, I set wrong port number on FR
