Sub internface shutdown in Frame Relay point to point in GNS3
Wilson Kwok
Hello
Please take a look on GNS3 file in attached, I'm sure already configured both routers s1/0 is no shut, but still status down, please help.
of course GNS3 supports it(but only on routers  which do Frame-relay switching) but these are your 2 DTE devices, no ? so they should be intf-type DTE and the switch where they are connected should be DCE(which is default for built-in GNS3 FR switch.
Alain
19 Replies 19
cadet alain
post your configs and  sh ip int br
Alain
R3:
R3#show run
Building configuration...
Current configuration : 1261 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
frame-relay switching
ip tcp synwait-time 5
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
encapsulation frame-relay
serial restart-delay 0
no fair-queue
frame-relay intf-type nni
interface Serial1/0.1 point-to-point
ip address 192.168.0.1 255.255.255.0
frame-relay interface-dlci 241
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
no ip http server
no ip http secure-server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  administratively down down
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Serial1/0                  unassigned      YES NVRAM  up                    down
Serial1/0.1                192.168.0.1     YES NVRAM  down                  down
Serial1/1                  unassigned      YES NVRAM  administratively down down
Serial1/2                  unassigned      YES NVRAM  administratively down down
Serial1/3                  unassigned      YES NVRAM  administratively down down
R4:
R4#sh run
Current configuration : 1251 bytes
version 12.4
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface Serial1/0
no ip address
no fair-queue
ip address 192.168.0.2 255.255.255.0
frame-relay interface-dlci 240
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4#sh ip int br
FastEthernet0/1            unassigned      YES NVRAM  up                    up
Serial1/0.1                192.168.0.2     YES NVRAM  down                  down
on both serial interfaces :
no frame-relay intf-type nni
Alain
Hi cadet alain
This lab is following our real environment, is GNS3 don't support frame-relay intf-type nni ?
Alain
Sorry, I don't understand, can you tell me how to do that ?
Completed with frame-relay intf-type dte on both router.
Hi Cadet alain,
Now I want to create sub-interface in s1/0, it allow me to create s1/0.1, but can't create s1/0.2, it showing "Incomplete Command", is it GNS3 bug ?
I think you might need to specify the type of sub interface it is after int s1/0.2 - Now, depending on your topology it could be either options.
Same as what you have done for your first sub-if. Example below of the options...
Rack1R1(config)#int s0/0/0.1
% Incomplete command.
Rack1R1(config)#int s0/0/0.1 ?
  multipoint      Treat as a multipoint link
  point-to-point  Treat as a point-to-point link
hth.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
You right, I forgot use the point to point command.
Now I have another problem, after I created s1/0.2 interface with ip address in both routers, I can ping each others with this subinterface ip address, but s1/0.1 can ping.
Please take a look in attached GNS3 file.
Thanks !
Hello, I was able to open the file, I saw R3 and R4 connected to a frame-relay switch, however there were no configs on the routers. Could you please post'em up here?
R3#show run
Current configuration : 1469 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
no fair-queue
ip address 172.16.228.21 255.255.255.252
interface Serial1/0.2 point-to-point
ip address 172.17.228.21 255.255.255.252
frame-relay interface-dlci 341
interface Serial1/0.3 point-to-point
ip address 10.10.228.21 255.255.255.252
frame-relay interface-dlci 441
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4#show run
Current configuration : 1459 bytes
version 12.4
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface Serial1/0
no ip address
no fair-queue
ip address 172.16.228.22 255.255.255.252
ip address 172.17.228.22 255.255.255.252
frame-relay interface-dlci 340
ip address 10.10.228.22 255.255.255.252
frame-relay interface-dlci 440
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Have you checked your frame-relay mapping on the frame-relay cloud is correct?
None of these DLCIs exist on CU and the same for DLCIs 340 and 440 on R4
Also you can get rid of the frame-relay switching command on both routers as they are FR DTE devices so they don't need to switch.
Alain
