04-29-2015 10:56 PM - edited 03-07-2019 11:48 PM
Hi there,
We are currently building a VSS and our design has L3 subinterfaces however we have hit a major wall while trying to do the following
Below is the output showing that the option of a subinterfaces seems to be available, but it still doesn’t apply
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#int po1
Switch(config-if)#no swi
Switch(config-if)#no switchport
Switch(config-if)#int po1.1
% Invalid input detected at '^' marker.
Switch(config)#int port-channel 1.?
<0-4294967295> Port-channel interface number
Switch(config)#int port-channel 1.1
Switch(config)#int tenGigabitEthernet 1/1
Switch(config-if)#exit
Switch(config)#int tenGigabitEthernet 1/1.?
<0-4294967295> TenGigabitEthernet interface number
Switch(config)#int tenGigabitEthernet 1/1.1
Switch(config)#
Here’s the show ver and show module output
Switch#show ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.07.00.E RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sun 07-Dec-14 22:13 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG11
Switch uptime is 5 minutes
Running default software
Jawa Revision 2, Winter Revision 0x0.0x41
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
*Apr 29 18:56:44.596: %SYS-5-CONFIG_I: Configured from console by console
License Information for 'WS-C4500X-32'
License Level: entservices Type: Permanent
Next reboot license Level: entservices
cisco WS-C4500X-32 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID JAE191304FG
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from PowerUp
1 Virtual Ethernet interface
32 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Switch#
Switch#show module
Chassis Type : WS-C4500X-32
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 32 4500X-32 10GE (SFP+) WS-C4500X-32 JAE191304FG
M MAC addresses Hw Fw Sw Status
1 b0aa.7777.5840 to b0aa.7777.585f 2.0 15.0(1r)SG11 03.07.00.E Ok
System Failures:
Power Supply: bad/off (see 'show power')
Switch#
All we can find is a little note on the release notes:
A Catalyst 4006 switch with Supervisor Engine III does not support subinterfaces or the encapsulation keyword on
Layer 3 Fast Ethernet, Gigabit Ethernet, 10-Gigabit Ethernet interfaces.
I am assuming this restriction applies to this platform but other than that there is nothing specifying we can't do this. Anyone out there has hit the same issue? or can anyone confirm this is an actual platform restriction
Thank you
Solved! Go to Solution.
04-30-2015 06:44 AM
The 4500 and 4500x series switches do not support sub-interfaces. Only 6500 series support sub-interfaces.
04-30-2015 06:44 AM
