Subnet Question
We have two 3750 core switches which will have six 2960 edge switches connecting it. We have three vlans:
vlan 1 - 10.1.1.1 255.255.254.0
vlan 2 192.168.2.0 255.255.255.0
vlan 3 192.168.3.0 255.255.255.0
My servers are using 10.1.1.x
My workstations are using 10.1.0.x
I am just wondering if i should use 10.1.1.1 255.255.255.0 for vlan 1 instead of the above?
Any help will be greatly appreciated?
Lake
7 Accepted Solutions
Reza Sharifi
Lake,
If you only have 254 devices on vlan 1 or fewer then for consistency use /24 (255.255.255)
also try not to use vlan 1.  That is the native vlan and it is mostly used for controll traffic.
so use vlan 2,3,4, or 10, 20,30 instead
Reza
Jon Marshall
Lake
Firstly you shouldn't use vlan 1 if at possible for any client traffic whether that be clients or servers.
Secondly it's not a good idea to have servers and clients in the same vlan. It is better to have servers in their own vlan as you can then control access to and from them with standard router acls on the L3 vlan interfaces.
If you separated out the clients from the servers then yes it may make more sense to use /24's for each subnet. If you want to leave the clients and servers in the same vlan then whether to use a /24 or as you are currently using a /23 depends on whether you have enough addressing.
If you can adopt a consistent subnet size it just makes everything a lot clearer in my opinion.
Jon
Lake
Yes it will work. You could always leave the servers temporarily in vlan 1 and move the clients to another vlan.
What is not entirely clear is why you are asking specifically about the subnet size ie. 255.255.255.0 or 255.255.254.0. Your L3 vlan interfaces do not have to have the same subnet mask ie. vlan 1 can have a different subnet mask/size to the subnet allocate to another vlan for example.
When you choose the subnet mask you simply choose it based on how many hosts/end devices you need in the subnet although generally speaking most people do not go above a /23 ie 255.255.254.0 because of potential broadcast issues.
255.255.255.0 is a common sized subnet. We used 255.255.255.128 in the last place i worked.
Jon
Lake
I'm assuming that your floor switches are connected to your core switches with L2 trunks ?
If so then yes vlan 1 will be on all switches so you can connect the printers to different switches on different floors into vlan 1.
Jon
Lake,
I would move the printers to vlan 4 (workstation vlan).  This way, you have one vlan (vlan 1) for all your servers and one vlan (vlan 4) for all your workstations and printers.  Or am I missing something here?
Reza
Yes that is a trunk configuration.
Note that you are not allowing vlan 1 across the trunk link however vlan 1 cannot be blocked off a trunk link (unlike all other vlans) so you should be fine.
Reza, as for moving the printers it could prove difficult if for example some clients have hardcoded printer IPs. They shouldn't but i have been bitten by this before.
Jon
Lake
Yes, simply include all the vlans you want allowed across the link.
Jon
17 Replies 17
Reza Sharifi
Lake,
Reza
Jon Marshall
Lake
Jon
We will design it like you guys mentioned but if we do that now we will have to change ip address on all the server including vmware. My boss wants to do it this way for now.
But will my setup work for now?
Lake
Lake
Jon
Thank you very much Jon.
I never thought about moving just the workstations to another vlan but i really like your idea. I will let my boss know and hear what he says.
I will leave the servers and printers in vlan 1 temporarily. 10.1.1.0. I will make the vlan 1 ip address 10.1.1.1 and change the ASA inside interface to another IP Address. In this case i won't have to change the servers default gateway.
I will create another vlan for example, vlan 4, and move the workstations there and i will assign ports on the 3960 edge switches to vlan 4.
All the servers will be connected to the core switch. Since we have two floors the printers won't be connecting to the core switch and they will be connecting to the edge switches. I think i can connect the printers to any switch because vlan 1 is assigned to all ports, is this correct? Trunking has been setup.
Lake
Lake
Jon
Jon,
I suppose the example below is a layer 2 trunk? Is this correct?
interface GigabitEthernet2/48
description xxxxxxxxxxx
switchport mode trunk
switchport trunk allowed vlan 2,3,5,10
channel-group 1 mode on
Lake
Jon
Lake,
Reza
I would love to move the printers but that will cause too much down time. We will schedule that for another time. My boss like the idea which Jon suggested. I guess we will go ahead with it.
Thanks guys,
Lake
I agree with you and Jon,
If it is too much work, then don't worry about it.  But if the printers are using DHCP then a reboot should take care of it.
either way, you have to keep the boss happy
Good luck
Printers are using static ip
Lake
Now i have to change my allowed vlans across all the trunk ports:
Change to commands:
switchport trunk allowed vlan 2,3,5,10,11,12,13
Is this correct?
Lake
Lake
Jon
