04-23-2018 06:33 AM - edited 03-08-2019 02:45 PM
Hello Guys,
My network is working on same vlan now. i have to create vlans and to accomplish that i need to seperate traffic on diff subnets .
Some questions :
1. for example i am using 10.110.16.0/24 subnet for vlan 10 but i have lot of extra IPs and i want to do more subnetting with this subnet and want to use 10.110.16.0/28. Is it possible to use these subnets in separate vlans ?
If yes please explain how to accomplish this ?
Solved! Go to Solution.
04-23-2018 08:25 AM
Since 10.110.16.0/24 is already being used, you can't take a /28 (10.110.16.0/28) from it and use it somewhere else. You would need to use a different subnet 10.110.17.0/24 or if you want to use 10.110.16.0/24, you would have to stop advertising it, change the mask and readvertise again. Note that this option will cause downtime if this subbed is in production. I recommend you use a completely different subnet and don't mess with the existing one.
04-23-2018 08:25 AM
