Subnetting problem - Magic number
trikantejabuka
Community Member
This is my IP address 174.121.14.165/23
/23  - 255.255.254.0
Magic number is: 256-254=2
Networks:
8
14
16 ...
Network address: 174.121.12.0
Broadcast address: 174.121.13.255        (12+Magic number -1 = 12+2-1 =13)
Where is mistake?
Please help me,
Greetings.
3 Accepted Solutions
John Blakley
Joni,
Your math is fine, but the network address that you have on your interface (your IP) will start at 174.121.14.0 - 172.121.15.255.
HTH,
John
HTH, John *** Please rate all useful posts ***
Joni,
The magic number, as you call it, is indeed 2 in the third octet of the netmask. Hence, you need to round down the third octet of the IP address to the nearest integral multiple of 2 when calculating the network address. However, in the IP address 174.121.14.165, the "14" is already an integral multiple of 2 so you do not change it. Right?
Best regards,
Peter
Joni,
In addition to what Peter said, the "magic number" is considered your boundary. For example, if your address the magic number is 2. Multiples of 2 would be the starting network address for the next block:
172.121.2.0
172.121.4.0
172.121.6.0
etc.
The magic number is the starting boundary for that network, and the broadcast address is -1 less than the next starting boundary:
172.121.2.0 - 172.121.3.255 (broadcast) (256 - 1)
The useable addresses are calculated like:
254 (in the second octet) (11111110)
0 = There are 8 bits left in the 4th octet = 00000000
So together it's 11111110.0000000
There are 9 0s in the host portion of your mask, so you get 512 hosts per network. Then you take 512 - 2 leaving you with 510 useable addresses (172.121.2.1 - 172.121.3.254)
HTH,
John
6 Replies 6
lgijssel
Level 11
Level 11
Was your ip not in x.x.14.0?
John Blakley
Joni,
HTH,
John
Thanks for the reply,
I know my IP address should be in the range 174.121.14.0 - 172.121.15.255, in my calculation
Network Address is: 174.121.12.0
Broadcast address is : 174.121.13.255, which is obviously wrong.
But I ask myself why, if I calculate correctly all.
Joni,
Best regards,
Peter
Joni,
172.121.2.0
172.121.4.0
172.121.6.0
etc.
HTH,
John
trikantejabuka
Community Member
Thank you all for  help, now I understand
Thank you!.
greeting from Bosnia
