SUP Engine
The_guroo_2
Level 2
Level 2
can someone please tell me the concept of sup eng and its different versions plz....i know that supis used for routing and switching......so then what is MSFC and ppl say MSFC is builtin.....like whats the main def between sup 1, 2 ,3 ,4 and now adays new sub 720.....thanks a million
mohammedmahmoud
Level 11
Level 11
The supervisor engine is a module that is installed in one of the card slots in the switch/router(more specifically the 7600). The supervisor engine provides switching and local and remote management for the switch/router.
The supervisor engine contains the following integrated daughter cards that perform forwarding and routing and provide the protocols supported on the router:
Multilayer Switch Feature Card (MSFC) is the control plane and does the following:
.Performs routing for the chassis. The MSFC contains the route processor (RP) and switch processor (SP) for the router.
.Runs Layer 2 and Layer 3 protocols, such as the Spanning Tree Protocol (STP) and others.
Policy Feature Card (PFC) is the forwarding plane and does the following:
.Performs Layer 2 and Layer 3 forwarding.
.Enforces access control list (ACL) functions.
.Performs policing and marking for QoS traffic.
.Collects Netflow statistics.
As for kinds of Sup, here you are the famous ones:
Cisco Catalyst 6500 Series Supervisor Engine 720
Cisco Catalyst 6500 Series Supervisor Engine 2
Cisco Catalyst 6500 Series Supervisor Engine 1A
Cisco Catalyst 6500 Supervisor Engine 32
And as a reference:
http://www.cisco.com/en/US/products/hw/modules/ps2797/prod_models_home.html
HTH, please rate if it does help,
Mohammed Mahmoud.
