Sup led status is orange??
ahmed.abdraboh
HI,
i have chassis 4507R with WS-X4516  sup , the status led of the sup is Orange
and this is the output?
what is the problem even the sup is working ok?
ABS_Core_SW#sh environment
no alarm
Chassis Temperature                    = 38 degrees Celsius
Chassis Over Temperature Threshold     = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
Power                                             Fan      Inline
Supply  Model No          Type       Status       Sensor   Status
PS1     PWR-C45-1400AC    AC 1400W   bad/off      bad/off  n.a.
PS2     PWR-C45-1400AC    AC 1400W   good         good     n.a.
Power supplies needed by system    : 1
Power supplies currently available : 1
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Switch Bandwidth Utilization : 0%
Supervisor Led Color : Orange
Module  1 Status Led Color  : Orange
Module  3 Status Led Color  : Green
Module  4 Status Led Color  : Green           PoE Led Color : Off
Fantray : Good
Power consumed by Fantray : 50 Watts
Reza Sharifi
Hi Ahmad,
The orange light is for one of the power supplies.  Turn on the first one and the light should turn green
Reza
hobbe
Level 7
Level 7
to quote the last speaker in this thread.
The yellow (amber) light it is for ps1 ie powersupply 1 who is busted or not operational.
check the powercable (both ends) so that it has not come loose and if you think you have redundant power know that you now do NOT have that and if it is not the powercable get a replacement if you do want to have redundancy.
if this is a powersupply faliure, then see it as you have dodget that bullet and get another spare powersupply.
Good luck
ok i will replace the faulty power supply
thanks
Ahmed
gcasadoh
If the supervisor Status Led is in solid orange, it is because the system is booting up or the diagnostic test is in progress.
Table 1 Supervisor Engine LEDs (WS-X4516)
LED
LED Status
Description
STATUS
Indicates the results of a series of self-tests.
Green
All diagnostic tests passed.
Red
A test failed.
Orange
System boot or diagnostic test is in progress.
Installation and Configuration Note for the Catalyst 4500 Series Supervisor Engine V
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/hardware/configuration/notes/78_15590.html
