Sup32
amitkaushik24
Cisco Catalyst 6500 Series Supervisor Engine 32 (WS-SUP32-10GE-3B)can support Cisco Catalyst 16 port Gigabit Module(WS-X6516A-GBIC) & Cisco Catalyst 48 port 10/100/1000 gigabit Ethernet Interface Module (WS-X6548-GE-TX)
pls let me know its urgent for me.
Jon Marshall
From the FAQ for Sup32
Q. Which line cards are supported by Sup32?
A. All classic line cards and all CEF256 line cards (without a Distributed Forwarding Card [DFC]) are supported at FCS
The 6548 & 6516A are CEF256 line cards and are not DFC line cards so you should be okay.
Be aware that because the Sup32 only uses the 32Gbps shared bus the throughput from these cards will be affected by this.
Jon
