Sup6-E vs Sup720
lxcollin1
Level 4
Level 4
I'm trying to decide between a Cat6K w/ Sup720 without dCEF vs a Cat4500 w/ Sup6-E. When camparing forwarding performance, the Sup6-E (250Mpps) seems to have better processing power than the Sup720 (48Mpps). Is this true?? In other words, unless I'm using DFC's, will the Sup6-E outperform the 720?
Lehi
Joseph W. Doherty
For just the forwarding performance of the supervisor alone (no 6500 line card DFCs), yes the sup6-E provides a higher PPS rate. However, the sup720 (15 or 30 Mpps - depends on line cards installed) provides more fabric bandwidth, 720 Gbps vs. 320 Gbps. The sup720 also supports more hardware and software features than the 4500, so you might want to consider more than supervisor performance.
Giuseppe Larosa
Hello Lehi,
as Joseph has noted you need to take in account also features.
Other collegues have reported that Sup6-E is really weak in features:
lack of netflow support
lack of NAT support
sup720 supports all this and also NAT giving you potential for L3 usage.
see
http://www.cisco.com/en/US/partner/products/hw/switches/ps4324/prod_models_comparison.html
or
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
Hope to help
Giuseppe
