SUP6L-e POST failed.
CATYO
Hello there.
I have a question.
SUP6L-E doesn't properly work.
Is this h/w issue ??
Thank you in advance :)
B2S#show diagnostic result module 1 test 1 detail
Current bootup diagnostic level: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
  ___________________________________________________________________________
    1) supervisor-bootup ---------------> F
          Error code ------------------> 1 (DIAG_FAILURE)
          Total run count -------------> 1
          Last test testing type ------> n/a
          Last test execution time ----> Feb 08 2015 23:56:09
          First test failure time -----> Feb 08 2015 23:56:09
          Last test failure time ------> Feb 08 2015 23:56:09
          Last test pass time ---------> n/a
          Total failure count ---------> 1
          Consecutive failure count ---> 1
Power-On-Self-Test Results for ACTIVE Supervisor
prod: WS-X45-SUP6L-E part: 73-14276-02 serial: JAE1652058E
Power-on-self-test for Module 1: WS-X45-SUP6L-E
CPU Subsystem Tests ...
 seeprom: Pass
Traffic: L3 Looopback ...
 Test Results: Fail
Traffic: L2 Loopback ...
 Test Results: Fail
Switching Subsystem Memory ...
 Packet Memory Test Results: Pass
Module 1 Failed
5 Replies 5
Leo Laohoo
The supervisor card is dead.  You may need to create a TAC Case using this thread.
Thank you : )
you can try do hard reset (remove the card and insert back again) . sometime sup card loose connection with back fabric will cause this issue. So mostly resetting card will help the sup to boot.
If the sup not recover even after resetting then most probably a hardware issue .
VS.Suresh.
*Plz rate the usefull posts *
Thank you !!
Same issue happened many time in our environment for 6500 series switches and solution is to hard/soft reset the module.
 If problem persists, problem with sup-engine
