SUP6L-E UPGARED
akram_nasr
We already bought Supervisor Engine module  SUP 6L-E  WS-X45-Sup6L-E . I need this module to support net flow protocol. I found that module doesn't support net flow.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/catalyst4000supervisors.pdf
The newest  supervisor engine that supports net flow is supervisor engine 7E
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/data_sheet_c78-612364_ps2797_Products_Data_Sheet.html
Comparison between SE 5 ,6 ,7
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
1- Can I upgrade this module (6L-E) to support net flow? If we can't, Can I replace this module with 7E module?
2- I found that part number     C4500E-SUP6L-SUP7
, Can it solve my problem ?
Akram Nasr
Reza Sharifi
Hi Akram,
You would have to by a new sup-7E to support net flow entries.  According to the link you provided a chassis that supports 6E-L, it also supports 7E
Amit Singh
Just to add to Reza's post, you can also look at the SUP7L-E which a light version of SUP7-E. SUP7L-E also supports flexible netflow and will be around the price range of SUP6L-E.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/data_sheet_c78-686325.html
Hope this helps.
Cheers,
-amit singh
