Sup720 licensing
MFerbrache_2
Please can anyone tell me if you need to purchase the Adv IP Serv license per chassis or per SUP?
Many thanks
Matt
abhischa
Hi Matt,
Only one software license for each feature set is required per chassis i.e. a chassis with redundant  Supervisor Engines does NOT require two licenses. The license file is mirrored on both supervisor modules. Even if both supervisor modules fail, the license  file continues to function from the version that is available on the  chassis.
Only module-based licenses require one license  installed per module that uses a licensed feature eg. SAN Extension over IP. The Adv IP Serv license is per chassis.
Hope that helps.
Cheers,
Abhishek
Please rate helpful posts
