SUP720 with X68XX Line Card
I have 6509E Chassis with SUP720B, Can I be able to insert X6816-10G-2T
Leo Laohoo
Not compatible.
Sup720 has DFC3/PFC3 while the 6816 is DFC4/PFC4.  This alone makes them incompatible.
Agree with Leo.
6800 modules required Sup2T.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
No, as the other posters have noted, but you could use the X6716-10G.  BTW this is compatible with the Sup2T if you upgrade the DFC to DFC4 (effectively making it a X6816-10G).  (NB: Most of the 68xx cards are really 67xx cards with the newer DFC4.  Most 67xx cards can be used with the Sup2t if using a CFC or upgraded to the DFC4.  [One exception is the 6708.])
