SVI's
aaronkb2002
Community Member
If I have a layer 3 switch ( 3850 ) configured with 4 SVI's ( VLAN ) -
conf t
interface vlan 1
ip address x.x.x.x
VLAN ( SVI ) 1 - 10.X.X.X
VLAN (SVI ) 2 - 20.X.X.X
VLAN (SVI) 3 - 30.X.X.X
VLAN ( SVI ) 4 - 40.X.X.X
I have servers on each VLAN with 2 NICS
will the servers need to be connected to each VLAN in order to pass packets between them ?
Thanks !!
Mark Malone
The servers will be able to talk to each other as there all connected to the same layer 3 switch , once you have not restricted the ports or applied any acls to the svis, its all in the same data plane
thank you , I did think that but just needed a CCIE confirmation !
Hello
"will the servers need to be connected to each VLAN in order to pass packets between them ?"
No they wont -
Enable ip routing on the L3 switch and assign the servers an access port relating to one of the vlans,
The servers will use a default-gateway which will be the  L3 awitch SVI interface to that partciular vlan the server is in and then you will have connectivity.
res
Paul
Kind Regards
Paul
