Switch 2901 HWIC-1FE, module detect but there's no interface.
faruqfarkhan
i have a 2901 router (IOS version 15.0(1)M9), I Have HWIC-1FE, systems detects this modules:
But when i check show ip int br it doesn't detect the fast ethernet module interfaces:
does any one know why that happened? i attached the boot up process
Thank you
DanielP211
Are you sure its supported on the C2901? The documentation dosent mention this.
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/ic/hardware/installation/guide/oview_ic.html
BR
****Kindly rate all useful posts*****
Hi Daniel
the link that you give is from 2007, and here the new compatibility that i found:
https://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd80581fe6.html
Regard,
Can you paste the boot up process?
BR
Hi daniel,
Here i paste the boot up process
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 512 MB - On-board = 512 MB, DIMM0 = 0 MB
CISCO2901/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 72/-1(On-board/DIMM0) bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x80803000, size: 0x1b340
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x3bd79fc
Self decompressing the image : ################################################# ################################################################################ ################################################################################ ################################################################################ ################################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
HWIC Slot 1 0x00200000
HWIC Slot 2 0x00200000
PVDM 0 0x00200000
Onboard devices &
buffer pools 0x0228F000
TOTAL: 0x0288F000
Rounded IOMEM up to: 44Mb.
Using 8 percent iomem. [44Mb/512Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M9, REL EASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 12-Sep-12 03:31 by prod_rel_team
Image text-base: 0x2100D9D8, data-base: 0x25963100
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FGL183620QF
2 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Press RETURN to get started!
Jan 2 12:00:03.231: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = ipbasek9 and License = ipbasek9
Jan 2 12:00:03.395: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = uck9 and License = uck9
Jan 2 12:00:03.543: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = datak9 and License = datak9
Oct 3 04:36:34.375: %PVDM-6-UNSUPPORTED: Codec G.723 is not supported on PVDM3.
Oct 3 04:36:43.879: %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x27
Oct 3 04:36:43.883: fe_mrvl_hw_init : Could not load driver
Oct 3 04:36:43.883: %ESWMRVL_FLTMG-7-INTERNAL_ERR: Internal error: Unable to in tialize the Marvell switch for FE
, -Traceback= 0x21200014z 0x213FBCF4z 0x213FCFD4z 0x213D925Cz 0x21138714z 0x213 DC548z 0x2344CE2Cz 0x2344CF14z 0x222750B8z 0x22275358z 0x233ECA14z 0x233EC9F8zhw ic_fe_analyze_interface: Couldn't initialize the HWIC FE
Oct 3 04:36:45.107: %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x27
Oct 3 04:36:45.107: fe_mrvl_hw_init : Could not load driver
Oct 3 04:36:45.107: %ESWMRVL_FLTMG-7-INTERNAL_ERR: Internal error: Unable to in tialize the Marvell switch for FE
Oct 3 04:36:48.547: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
Oct 3 04:36:48.547: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
Oct 3 04:36:48.547: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
Oct 3 04:36:49.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe rnet0/0, changed state to down
Oct 3 04:36:49.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe rnet0/1, changed state to down
Oct 3 04:36:51.631: %SYS-5-CONFIG_I: Configured from memory by console
Oct 3 04:36:52.799: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed stat e to administratively down
Oct 3 04:36:54.735: %SYS-5-RESTART: System restarted --
Oct 3 04:36:54.739: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Oct 3 04:37:06.083: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
Router>show ip int br
GigabitEthernet0/0 192.168.0.1 YES NVRAM down down
GigabitEthernet0/1 unassigned YES NVRAM administratively down down
Router>show inven
