switch 2960G-24TC-L
engmohamad1980
Hello
i have switch 2960G-24TC-L when i'm insert 1000BASE-SX module to the port Giga 0/23
and i can't see the LED go to green on this port , and when i run command
# show inventory
doesn't see the fiber module ,
only see 2960G-24TC-L
what's problem maybe the module problem or must work thing on switch to work ,
and what i want work on switch to active this port on fiber and disable it on ethernet UTP
help me
6 Replies 6
Giuseppe Larosa
Hello Mohamad,
try the following:
config term
int gi0/23
media-type sfp
to tell the switch you want to use the fiber based module and not the rj45
Hope to help
Giuseppe
thank you
i'm trying this command but no result.
and i'm insert FX module and execute
#show inventory
i'm notice the switch see the module .
when insert sx mdule the switch don't see anything
and i want ask if insert the module to switch the port led must be green ot flush or not ??
Hello Mohamad,
try also
conf t
int gi0/23
shut
no shut
the config guide lists only 100 Base X SFP
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_46_se/configuration/guide/swint.html#wp1028628
So I wonder if it supports a real GE fiber based port
It is supported starting from release 12.2(25)FX
see table 4 in the following
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp128965
Hope to help
Giuseppe
Leo Laohoo
Is the GLC-SX-MM from Cisco or is it from a third-party?
Is Interface Gig0/23 in error disable?
Is Interface Gig0/23 also being used by a copper line?
Have you tried to put this SFP somewhere else?
Have you tried other SFP?
hello
i'm discover the module have problem .
but i want know why the 100Fx module doesn't work fine ,
hello
