Switch 3650 drop SNMP traffic
itpanda
Dear all
 I have two 3650 switch and they are configuring SNMP services to monitor status port. But They often alert "down snmp traffic". Then I checked switch log which show "drop packet snmp". like image, I attached it belowsnmp_issue.PNG
Anyone can help me about the case. thank you so
there are numerous bugs out there that could apply. Which IOS version is your switch running ?
Try to stop (no snmp-server) and start the SNMP engine...
I restart snmp engine but the same issue and my version like image below.
Hello
Even though its not on the same plaftorm it could be down to possible buggy software if applicable try an upgrade -  here
Kind Regards
Paul
