Switch automatically restarts for no reason , Please help me
blackjack
Switch automatically restarts for no reason , I have upgraded the software.
can not find fault. more crashinfo, see the following output:
HKZ-SSL-4-NAN-4506#more crashinfo:data
Current Time: 5/27/2013 10:28:10
Last Power Failure: 05/08/2013 16:55:28
Last Reload Status: 00000000
Last Software Reset State: 00000301
Crashdump version: 1
HKZ-SSL-4-NAN-4506#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICES-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 11:57 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x12C245CC
ROM: 12.2(44r)SG5
Darkside Revision 4, Nexu Revision 9, Fortooine Revision 1.22
HKZ-SSL-4-NAN-4506 uptime is 5 days, 15 hours, 51 minutes
System returned to ROM by reload
System restarted at 18:47:57 Beijing Tue May 21 2013
System image file is "bootflash:cat4500e-entservices-mz.122-54.SG1.bin"
Last reload reason: Unknown reason
cisco WS-C4506-E (MPC8548) processor (revision 8) with 524288K bytes of memory.
Processor board ID FOX1332GCL0
MPC8548 CPU at 1GHz, Supervisor 6L-E
Last reset from Reload
2 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
HKZ-SSL-4-NAN-4506#sho module
Chassis Type : WS-C4506-E
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     6  Sup 6L-E 10GE (X2), 1000BaseX (SFP)    WS-X45-SUP6L-E     JAE1333GH8X
2    48  1000BaseX SFP                          WS-X4448-GB-SFP    JAE1331FSIA
M MAC addresses                    Hw  Fw           Sw               Status
1 0026.cbe0.2bc0 to 0026.cbe0.2bc5 1.0 12.2(44r)SG5 12.2(54)SG1      Ok
2 0023.eb22.4390 to 0023.eb22.43bf 1.3                               Ok
HKZ-SSL-4-NAN-4506#show environment temperature
Module Sensor                     Temperature          Status
1      air inlet                  40C (51C,65C,68C)              ok
1      air outlet                 49C (69C,83C,86C)              ok
HKZ-SSL-4-NAN-4506#
Last Software Reset State: 00000301-------------it is a hint, but I did not find the Cisco relevant information on
10 Replies 10
Leo Laohoo
Check you power.
Can you post the output to the command "sh env status".
nkarpysh
Can you pls provide following command:
show platform crashdump
HTH,
Niko
HKZ-SSL-4-NAN-4506#show platform crashdump
Current Time: 5/27/2013 13:12:3
HKZ-SSL-4-NAN-4506#
No more information ,  may be the engine is broken?
Duplicate posts.
HKZ-SSL-4-NAN-4506#   sho environment status
Power                                             Fan      Inline
Supply  Model No          Type       Status       Sensor   Status
PS1     PWR-C45-1400AC    AC 1400W   good         good     n.a.
PS2     PWR-C45-1400AC    AC 1400W   good         good     n.a.
Power supplies needed by system    : 1
Power supplies currently available : 2
Switch Bandwidth Utilization : 0%
Supervisor Led Color : Green
Module  1 Status Led Color  : Green
Module  2 Status Led Color  : Green
Fantray : Good
Fantray removal timeout : 30
Power consumed by Fantray : 120 Watts
HKZ-SSL-4-NAN-4506#
No unusual circumstances, the news is a long time ago
As the Sup module has crashed many times now and there is no crash dump been generated.
There is a silient bug for this kind of issue I cannot share it publically.
Action plan:-
It looks to me that the sup module is faulty. Go ahead and create the RMA for the same.
Inayath.
*Plz rate all usefull posts.
7609 router can generate crash files, but can not seem to switch 4506, or that the job you need to configure what order? If necessary, tell me what commands,  Thank you very much
Hi black,
all cisco Switches does generate the Crash info files very often. As I told in my earlier post that you are hitting the silent bug due to which the crash file didnt got generated on this switch.
The issue is related to the sup module on your switch. There is nothing much you can do other than replacing the same.
Please revert for any further clarification.
Inayath
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Okay, I understand. Although my problem has not yet resolved, but still very grateful to everyone for helping. Google online translation is really a good tool,
Okay, I understand. Although my problem has not yet resolved?
I have tried to provide you the solution. Let me know if that has not helped you?
Archiving Crashfiles Information
This feature allows you to archive crashinfo files (otherwise overwritten if another system reset were to happen first to the bootflash). Having access to archived crashinfo data greatly assists in troubleshooting.
To archive crashinfo files, perform this task:
Command
Purpose
Step 1
Switch# configure terminal
Enters global configuration mode.
Step 2
Switch(config)# exception crashinfo file bootflash:name
Enables archiving crashinfo files to bootflash. The files are stored in bootflash with the name specified concatenated with the date.
Step 3
Switch(config)# end
Returns to privileged EXEC mode.
Step 4
Switch# show running-config
Verifies your entries.
Step 5
Switch# copy running-config startup-config
(Optional) Saves your entries in the configuration file.
Displaying a Crash Dump
A crash dump provides the following information:
Malloc or free traces
Chuck alloc/free traces
Process block dump
Register memory dump
Current proc stack partial decode
Interrupt level stack
Last 128 memory block dump
To display a crash dump, do the following:
Switch# show platform crashdump
Inayath
