Switch C9200L snmpv3
gaigl
Level 3
Level 3
we're starting with CatCenter (v2.3.7.9) and we've some Switches 2960X and 9200L.
I can manage both Models bot on the 9200 I've got Issues with snmpv3:
Every few Minutes I get Message %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host $CCenter.
In the Device-Logs on CCenter a lot of Messages DEVICE_AVAILABILITY:REACHABLE and DEVICE_AVAILABILITY:PING_REACHABLE
One of the 9200 I've updatet from 17.9.5 to 17.12.5 (from the CatCenter), nothing changed
the snmpv3 User is in a Group with write access, another snmpv3 user from a Monitoring System with read access is working fine, so the snmp Configuration is working fine
The netconf-yang status is fine.
Do you have any hints, where to look for the Issue?
Thanks a lot
Karl
gaigl
Level 3
Level 3
I guess the reason was the snmp engine ID.
when I remove snmp users, groups and engine ID and reenter groups and users, there's a new engine ID and failures are gone
Is there's a way for the CC to work with the existing ID?
we are currently only provisioning existent devices
Sorry but can I ask something
You run 2960x with CCC? Is it fully work?
As I know this old SW not support Integration with CCC
MHM
gaigl
Level 3
Level 3
sure, the Functions are limited, but I see EOL Status, Software, Device Infos, that's ok, I guess I can manage Software-Updates, will try next.
the 2960X don't have netconf
If you are looking in the Compatibility Matrix, you see the Details
gaigl
Level 3
Level 3
