Switch Comparison for Compatibility
nirajp
I have a Stack of 3 switches WS-C3750-48PS-S.
I need to add one WS-C3750-48TS-S to this stack . will there be any compatibility issue ?
iyde
Level 4
Level 4
No.
Obviously you won't have PoE on the new switch but that ahs nothing to do with the stacking.
Ingeneral, any Cat3750 can be put into a stack with other Cat3750, and by doing that you can get the various interface types you might need.
HTH.
Joseph W. Doherty
As Ingolf notes, in general you can mix any model 3750 within the same stack.
The only compatiblity issue that comes to my mind is the fiber only 3750 supports a SDM template not supported by the other models. (You can still mix models, but need to insure the special template isn't configured.) However, this shouldn't arise for your noted models.
Thanks Joseph
