SWITCH CONFIGURATION
Hi, I just bought a cisco SG200-26P smat switch but i am unable to integrate it with the current network. The excisting network has a cisco 4300 series router that has vlan 5 for wireless, vlan 6 for lan and vlan233 for voice. 2 switches both catalyst 3750 series. I need to get the SG200-26P working on the network. Kindly help
Giuseppe Larosa
Hello Joseph,
first of all, you need to download the administration guide for your switch
for example
edit:
do not use the link I had provided it tries to install software on your PC I have deleted the link
use the cisco link below
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/administration_guide/Cisco_200Sx_v1_4_AG.pdf
Then, you use the Get Started chapter for initial setup.
Later you need to create all the required Vlans for your network scenario
233
You have probably a router on a stick configuration with subinterfaces on the Cisco router 4300, you need to connect the swich to the router using a trunk port that allows the required Vlans 5,6,233
Edit2:
You can use smartport type Router on the port toward the router see pag 146 of the above guide.
Hope to help
Giuseppe
