08-14-2013 01:08 AM - edited 03-07-2019 02:55 PM
Dear Folkz,
Does cisco 4948 switch support SDM (Switch database Management) ??
please proivde relevent link for reference if avaialable .
Thanks in advavance !!
Solved! Go to Solution.
08-14-2013 01:32 AM
Muru,
SDM is not supported on the platform you have requested. The following are the devices were you can select the feature:
Inayath
*****Plz rate the usefull posts********
08-14-2013 01:32 AM
Muru,
Inayath
08-14-2013 05:28 AM
Dear Sharieff,
Thxz a lot for your support. Could provide me any refernece link for the same ??
08-14-2013 05:30 AM
Muru,
Kindly use the Feature navigator it helps.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Inayath
*Plz rate all usefull post.
08-14-2013 05:43 AM
Dear Sharief,
Your post is very much helpful for my all issues. Thank you so much 🙂
Muruganantham A.
