switch does not boot
Network Pro
Hi all,
i have another problem as well...i have 2960 but does not seem to boot at all
all i get on the screen is
Using driver version 1 for media type 1
Base ethernet MAC Address: 00:23:ab:1a:1d:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
wouldnt bring up any prompt...
any thoughts?
POST: inline power post failed for port 2
Looks like it is a hardware problem
5 Replies 5
fgasimzade
Level 4
Level 4
Thaks for the reply.. tried this earlier but came up with this error:
i cant even break to boot sequeence now..i am using taraterm
switch: boot
Loading "flash:c2960-lanbase-mz.122-44.SE2/c2960-lanbase-mz.122-44.SE2.bin"...@@
File "flash:c2960-lanbase-mz.122-44.SE2/c2960-lanbase-mz.122-44.SE2.bin" uncompr
essed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(44)SE2, RELEA
SE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 01-May-08 12:45 by antonino
Image text-base: 0x00003000, data-base: 0x01000000
Initializing flashfs...
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes     : 3870720
mifs[3]: Bytes used      : 1024
mifs[3]: Bytes available : 3869696
mifs[3]: mifs fsck took 0 seconds.
mifs[3]: Initialization complete.
mifs[4]: 527 files, 19 directories
mifs[4]: Total bytes     : 27998208
mifs[4]: Bytes used      : 10037760
mifs[4]: Bytes available : 17960448
mifs[4]: mifs fsck took 0 seconds.
mifs[4]: Initialization complete.
...done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
front_end/ (directory)
extracting front_end/fe_type_3 (75656 bytes)
extracting front_end/front_end_ucode_info (129 bytes)
extracting front_end/fe_type_4 (75656 bytes)
extracting ucode_info (76 bytes)
POST: Inline Power Controller Tests : Begin
POST: inline power post failed for port 0
POST: inline power post failed for port 1
POST: inline power post failed for port 3
POST: inline power post failed for port 4
POST: inline power post failed for port 5
POST: inline power post failed for port 6
POST: inline power post failed for port 7
POST: inline power post failed for port 8
POST: inline power post failed for port 9
POST: inline power post failed for port 10
POST: inline power post failed for port 11
thanks...i thought of the same as well..do you think breaking the boot sequence will give joy ?
If there is a  hardware problem it won't do any good to break boot sequence.
Regards.
Alain.
