switch flash error message
zain_gabon
Hi All,
i have a problem with my catalyst 3560 PoE switch.
it's do not started and i have the switch: prompt.
i do the procedure flash error;
switch: flash_init
switch:load_helper
but when a get switch: dir flash:
i have this error message
unable to stat flash:/: invalid argument
so, i cannot load a new image or anything,
can someone help me?
zain_gabon
hello,
find the output of flash_init and dir flash
switch: flash_init
Initializing Flash...
flashfs[0]: sector 83, block 249 checksum (0xbea4 != 0xe2f0)
flashfs[0]: writing to flash handle 0x7e106dc, device 0, offset 0x1f20000, length 0x208: Illegal Operation -- setting bit(s) with write operation
flashfs[0]: sector ptr: {0xf9, 0x53}
...done Initializing Flash.
Setting console baud rate to 9600...
switch: dir flash:
switch:
Dear Support,
After many actions, my switch start properly.
i don't know witch command resolve the issue.
may be this one
set manual BOOT=flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin
