Switch Hyper Terminal Problem
ravi.gyala
Community Member
when we want to connect switch though Hyper Terminal it showing following problem:-
% No defaulting allowed
Enter interface name used to connect to the management network from the above interface summary:
Giuseppe Larosa
Hello Ravi,
the switch has an empty configuration and you are during initial setup where it puts you questions like the one you have reported.
This question asks what of the interfaces with an ip address has to be used to look for a default gateway/default route
you can skip all this and you can manually configure the device or you can take advantage of initial setup to have some parameters configured like hostname, ip addresses on interfaces and where to look for a default gateway/default route
Hope to help
Giuseppe
Giuseppe Larosa
Hello Ravi,
Hope to help
Giuseppe
hi qiuslar
thx now i have work it.
