Switch isolation
daveytho
Does Cisco make a product that provides switch isolation between LAN segments so that there is an air gap between the lans
hi Davey,
I'm not sure what you mean "air gap". Cisco switches had provided "VLAN" to isolate between lan segments (if configured)
The other vendor switches can also do.
If it wasn't correct,please explain a bit more about your question.
Toshi
What I need to do is switch between lans with a physical switch. Air Gap means in a secure environment the two lans are never physically connected
