switch not boot
Ramprasad2
hi team,
i have Cisco 9200L its not boot properly its showing below logs
Initializing Hardware...
Bus is busy - 0x2(status)
ERROR: TAM write failed (3000)
act2_read_raw_idprom failed...
Unable to read byte 1. Timing Out !
System Bootstrap, Version 17.9.1r [FC8], RELEASE SOFTWARE (P)
Compiled Sat 07/23/2022 16:14:02 by rel
Current ROMMON image : Primary
platform with 2097152 Kbytes of main memory
TAM Init Failed
TAM Init Failed
boot: attempting to boot from [cat9k_lite_iosxe.17.03.06.SPA.bin]
Please wait while the system restarts.
TAM Init Failed
TAM Init Failed
TAM Init Failed
TAM Init Failed
8 Replies 8
Reza Sharifi
Open a ticket with TAC. You may need to RMA it if it is a hardware issue.
Leo Laohoo
Call Cisco TAC and organize an RMA for the switch is dead.
randolph_harris
I'm getting the same on one of my 9200L's. A work around until you can get it replaced is to unplug the power cord, wait for a few seconds and then plug the power cord back in and hold down the mode button until you see
boot: failed to load flash:/user/packages.conf (Aborted)
ERROR: failed to boot from flash:packages.conf (Aborted)
at the switch: prompt type reset and the y
it should boot normally from that point
After doing the workaround above. I downgraded the IOS from cat9k_lite_iosxe.17.03.06.SPA.bin to cat9k_lite_iosxe.17.03.05.SPA.bin which cleared out the issue
How do it this when the device no boot complete?
i did same
i typed reset but it doesn’t go past
initializing hardware…
system bootstrap, version 17.9.1r [FC8],Release software P
current ROMMON image:primary
C9200-24T platform with 4194304kbytes of memory
TAM init failed
TAM init failed
boot:attempting to boot from[flash:packages.conf]
Instead of typing the reset command do a physical pull of the power cord
randolph_harris
As soon as you apply power, press the mode button. It should take you to the location where you can do it.
