Switch performance problem
Andrekap70
Community Member
Hi all,
i'm experiencing a performance issue on a switch Cisco 2960.
When there is a heavy traffic between 2 machines (huge files copy), there is a slow down also in communication between other machines connected to the same network.
All the machines are working in 100 Full Duplex.
At this moment i do not have access to the switch configuration, but i would like to understand if there is some misconfigured parameter that can cause this kind of behavior.
Thank you very much
Best regards
Andrea
nspasov
Hello Andrea-
It would be best if you can get access to the switch first. It is very possible that the switchports are running in half duplex vs full. Other things that could be wrong are MTU, buffers, QoS, etc.
Thank you for rating helpful posts!
Neno,
i'm sure that the machines are running Full Duplex.
But what is not clear to me is how it's possible that heavy traffic between machines A and B can slow down communication between machines C, D and E.
I thought that the switch could separate completely the data flows.
Is there anything i'm missing?
thanks
Andrea
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If they are not, duplex mismatch generally really, really slows transfer rate.
In theory they can, but in practice much depends on the nature of the data flows and the architecture of the switch.  Unfortunately, the 2960 is designed more as a user edge switch than a high performance switch.  For example, the 2960, I believe, only has 2 MB of buffer RAM shared by all ports.
Or, for example, when you write "between machines C, D and E", if C and D are sending to E, concurrently, you can often easily generate egress congestion on the port to E.
Or, if the heavy traffic between A and B is not all ASIC handled, other non-ASIC traffic will be impacted.
To further analyze the situation, you need to look at the switch stats for resource issues.
