Switch Port Access
Please refer the below Senario ,
Switch 1 ------ Switchport mode access ----- Switch 2
PC1 in VLAN 2                                             PC 2 in VLAN3
In this senario you ca see that PC 1 is configured in VLAN 2 & PC 2 is configured in VLAN3 & the cable that connect between Switch 1 & Switch 2 is configured as a Access Port.
Then can PC 1 communicate with PC 2 if they are in different VLAN.
If No then Why ?
Chetan Kumar
Edison Ortiz
With Cisco switches, you will receive Vlan mismatch messages with CDP but your design will work.
Theory put on practice:
Rack1SW2#sh ver | i IOS
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Rack1SW1#sh ver | i IOS
On Switch 1
interface GigabitEthernet0/15
switchport access vlan 112
  switchport mode access
interface Vlan112
ip address 1.1.1.1 255.255.255.0
On Switch 2
switchport access vlan 122
interface Vlan122
ip address 1.1.1.2 255.255.255.0
Rack1SW2#ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
Rack1SW2#
Rack7Pod1>1
[Resuming connection 1 to sw1 ... ]
*Mar  9 17:47:11.859: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet0/15 (112), with Rack1SW2 GigabitEthernet0/15 (122).
Rack1SW1#ping 1.1.1.2
Sending 5, 100-byte ICMP Echos to 1.1.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/8 ms
Rack1SW1#
John Blakley
I would say YES. Here's why.
If you have  a port on the edge (switch 1) configured as an access port, that  automatically means that the traffic coming through that port is now  untagged. It's native VLAN is now 2 on that port. When you put the  uplink that connects to switch 2 as an access port on both ends, you've  configured those as untagged as well, and the same thing goes for PC2 as  an access port.
The only thing is that both computers would have to be on  the same subnet. If they're on different subnets, then you'd need a  router in between to route the vlans.
Although, I'd need to test this
*** Edit *** I tested this in GNS, and I can't get it to work. In theory it should work, but best practice anyway would be to have your switch interconnected links as trunk ports.
HTH,
John
HTH, John *** Please rate all useful posts ***
As per theroy it should work , But to get result we should test the same on praticle devices.
But Thanks for you reply.
Chetan Kumar
Edison Ortiz
On Switch 1
interface Vlan112
On Switch 2
interface Vlan122
Rack1SW2#
Rack7Pod1>1
Rack1SW1#
Hi  Edison
Thanks for you an helpful explanation & sharing the praticle result.
So i was thinking correct , If i configured access port between both switches then it won't see the vlan tag ,Ir work with Broadcast mode.
Different VLAN can communicate in mention senario.
Chetan Kumar
