Switch port not responding.
faizal004
Community Member
I have a 24 ports cisco catalyst 2960 series SI switch running fine expect a single port.
could you please advise a check list.
cordilal regards-
faizal
InayathUlla Sharieff
Okay here is the checklist:
1- Try changing the cable.
2- Connect new cable and other end to your laptop see if hte light turns to green.
3- Do a TDR test if you want.
4- If in case you happen to see no lights when conected with good cable then port is faulty.
5- Hence you would be left with 2 options:
a) Run the switch with 23 ports.
b) If you have contract get the switch RMA.
Martin Carr
Level 8
Level 8
Stating the obvious, I assume you have checked the interface is not shutdown or been err-disabled?
Martin
