switch port
ebraa2401
Community Member
I would like to ask
why Cisco create dynamic auto switch-port mode if dynamic desirable founded ?
where we use dynamic auto ?
Difference between Dynamic Desirable and dynamic auto
Dynamic Desirable
by default dynamic desirable meaning that if you connect one switch to another switch it will automatically negotiate a trunk.
a default 3550 port will create a trunk when connected to any other port except one that is configured as a access port.
Dynamic auto
A default 3560 port will create a trunk when connected to any other port except one that is configured as a access port OR a port configured as “switchport mode dynamic auto.”
find the some of  the combination which will help you understand easily .
Switchport Mode Access Dynamic Desirable Dynamic Auto Trunk
Access No Trunk No Trunk No Trunk No Trunk
Dynamic Auto No Trunk Trunk No Trunk Trunk
Dynamic Desirable No Trunk Trunk Trunk Trunk
Trunk No Trunk Trunk Trunk Trunk
DTP configurations:
Access
Switch(config-if)# switchport mode access
Dynamic Auto
Switch(config-if)# switchport mode dynamic auto
Dynamic Desirable
Switch(config-if)# switchport mode dynamic desirable
Trunk port
Switch(config-if)# switchport mode trunk
https://ccnatoccie.wordpress.com/2010/12/16/difference-between-dynamic-desirable-and-dynamic-auto/
http://bradhedlund.com/2007/11/27/switchport-configurations-explained/
https://learningnetwork.cisco.com/thread/5882
regards,
-Do rate helpful posts.
i know that but why Cisco created dynamic auto ? dynamic desirable Enough we don't need dynamic auto
switchport mode dynamic auto - allows the port to negotiate DTP if the other side is set to trunk or desirable. Otherwise it will become an access port
question:why Cisco created dynamic auto ?
Answer:- that was created who doesnt want to use the configuration mode of desirable were in the port goes out for negotiating.
Inayath
Auto keyword has some significance , Like if the port is connected with a third party device and they don't want to make special changes as per your need. In that case dynamic auto plays a good role which allows the port to negotiate DTP if the other side is set to trunk or desirable. Otherwise it will become an access port.
Which is also explained by InayathUlla.
Hope it Helps..
-GI
