Switch Privilege 7 Access and Secret Password
Rajan R
Hello, Gave a user Privilege 7 access. But when he uses the enable password, user gets full access. IF i create a enable password with privilege 7, the switch does not accept the password. What am I doing wrong ? Thanks
Mark Malone
Can you post exactly what you have configured for that user or lock him down using priv exec level commands so you can tell him what he can cant use in enable
http://www.cisco.com/c/en/us/td/docs/ios/12_2/security/configuration/guide/fsecur_c/scfpass.html#wp1001357
Defining an Enable Password for System Operators Examples
In the following example, you define an enable password for privilege level 10 for system operators and make clear and debug commands available to anyone with that privilege level enabled.
enable password level 10 pswd10
privilege exec level 10 clear line
privilege exec level 10 debug ppp chap
privilege exec level 10 debug ppp error
privilege exec level 10 debug ppp negotiation
The following example lowers the privilege level of the more system:running-config command and most configuration commands to operator level so that the configuration can be viewed by an operator. It leaves the privilege level of the configure command at 15. Individual configuration commands are displayed in the more system:running-config output only if the privilege level for a command has been lowered to 10. Users are allowed to see only those commands that have a privilege level less than or equal to their current privilege level.
enable password level 15 pswd15
privilege exec level 15 configure
privilege exec level 10 more system:running-config
Disabling a Privilege Level Example
In the following example, the show ip route command is set to privilege level 15. To keep all show ip and show commands from also being set to privilege level 15, these commands are specified to be privilege level 1.
privilege exec level 15 show ip route
privilege exec level 1 show ip
Thanks a lot Mark for your response.
I have a user with privilege 7. I created a enabled password with privilege 7, but when i login with the user and use the enable password, the switch does not accept it.
Hi can you post what way you have set the config up , I cant really offer more without seeing the config side , if you certain its right could be something buggy with the ios version for the privilege
Hello
Below is a example for limited privilege access I use for our local desktop guys to enpower them to enable access ports.
Example:
username LBS privilege 2 secret 5 $1$YoS9$I2HyxidT7YpDcNAMePHbR1
privilege interface level 1 spanning-tree portfast
privilege interface level 1 storm-control
privilege interface level 1 switchport
privilege interface level 1 description
privilege interface level 1 default spanning-tree portfast
privilege interface level 1 default storm-control
privilege interface level 1 default switchport
privilege interface level 1 default description
privilege interface level 1 no spanning-tree portfast
privilege interface level 1 no storm-control
privilege interface level 2 no shutdown
privilege interface level 1 no switchport
privilege interface level 1 no description
privilege interface level 2 shutdown
privilege interface level 2 default shutdown
privilege configure level 2 interface
privilege configure level 2 default interface
privilege configure level 2 no interface
privilege exec level 1 show running-config
privilege exec level 1 do-exec show running-config
privilege exec level 2 configure terminal
privilege exec level 2 do-exec configure terminal
res
Paul
Kind Regards
Paul
