Switch recommendation?
mcvosi
I'm currently using a 3550-12T as a core router for my small network.  I'm wanting to upgrade to something newer that runs an IOS that supports WCCP2.
I need layer 3 functionality with at least 10 - GigE ports.
Any recommendations?
Thx
Reza Sharifi
You can use a 3560X.  it will provide you with 10Gig uplinks or 1 Gig uplinks. It will also work as layer-2 and layer-3
Here is the data sheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.pdf
Somasundaram Jayaraman
This link might interest you.
3550 WCCP2:
http://www.cisco.com/en/US/products/hw/contnetw/ps761/products_configuration_example09186a0080160b28.shtml
-   3550 running Cisco IOS® Software Release 12.1(11)EA1a supports WCCP 2.
Also I can see from the release notes that 3750 switches supports WCCP 2.
IOS version:
12.2_52_SE
Switches:
3750 series.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/swwccp.html
Datasheet for 3750 Switches:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
++ If you looking for higher range of switches you can go for 4500 or 6500 series.
Hope this helps..
Cheers
Somu
Rate helpful posts
Leo Laohoo
Can you be more specific?
You currently have a 3550-12T so that means that you have ten 10/100/1000BaseTx.  Do you want to have access ports as copper or fibre?
How many 10Gb do you need?
If you need only two then I'd recommend the 3560E-12SD (no stack-able switch model) or 3750X-12S or 3750X-24S.  The 3560E-12D can support up to twelve 10Gb interface.
If you want your access ports to be copper then you have alot of choices.  3560E/X, 3750E/X are likely candidates.
