Switch recommendations
wbunch
Community Member
I know I am talking old technology here so bear with me.
I am needing to replace two switches soon. The first switch minimum requirements are 12 ports 10/100 TX (only) and one 10/100/1000 TX. The second switch minimum requirements are 12 ports 10/100 TX, 1 port 1000 TX and two or four 100 SX. Can you please provide a few links.
Thanks……….
ankurbhasin
Level 11
Level 11
HI Wbunch,
Check this link
http://www.cisco.com/en/US/products/hw/switches/index.html#products
It has all the switches listed and you can go for optiosn in 2950 and 3550 switches.
Ankur
Hi Wbunch,
It may not exactly matches the same requirement you have but yes I think for your first requirement you can go for
2950T 24 which has 24 10/100 ports and two fixed 10/100/1000BASE-T uplink ports
For your second requieremnt you can check this link
http://www.cisco.com/en/US/products/hw/switches/ps5528/index.html
Ankur
