switch REP single segment with dual media (combine REP and portchannel)
ahmed
Hi all,
sorry i edited my question, i need to make REP with double link (4 ports, 2 ports each link, since 1 switch can have no more than two ports that belong to the same segment, so i will user port channel).
i have several C9300 and need to make ring topology with double link using port channel. i will use REP.
please share some example configuration for this or simple guide i can follow.
i tried in packet tracer v7 but failed, i can do config port channel mode auto and rep, but if i dissconnect 1 of port, the rep didn't work.
if you have some example config it would be great.
thanks
ahmed
I don't think Packet Tracer lets you fully configure REPs.
The link below is for the Catalyst 1000 switches, but it should work on the 9300 the same way.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/software/releases/15_2_7_e/configuration_guides/lyr2/b_1527e_layer2_c1000_cg/configuring_resilient_ethernet_protocol.html
jmcgrady1
A related question: Say i have ten 9300 switches in a ring. Can i run two separate REP rings across them? Both carrying all vlans? Or is only one REP ring possible?
