switch routing between layer 2 and layer 3 router
pcfreak49
Question how I can switch routing between layer 2 and layer 3 switches?
5 Replies 5
Antonio Knox
Level 7
Level 7
I'm not clear on your question, but here goes.....
If by switch routing you mean multilayer switch, to enable switching and routing between the two simply enable routing on the switches (I'm assuming you have vlan interfaces with ip addresses already configured in this example:
Example
Switch A
Switch(config)# ip routing
Switch(config)# int gig0/25
Switch(config)#sw mode trunk
Switch(config)#no shut
Switch(config)#end
Switch B
Switch(config)#end
If you want to connect multiple routed vlans between two switches, you will need either a router (which you don't have apparently) or you will need to make the layer 3 switch a router and trunk Vlans configured on that switch.
Example
Switch A
Switch(config)#vlan 10
Switch(config)#int vlan 10
Switch(config)#ip address 10.10.10.1 255.255.255.0
Switch(config)#vlan 20
Switch(config)#int vlan 20
Switch(config)#ip address 10.20.20.1 255.255.255.0
Switch B
Please rate helpful posts.
No it is between a layer 2 switches and layer 3 router
In that case what you need to do is configure the VLANs on the switch, set the port on the switch that communicates to the router as trunk and define an encapsulation type for the trunk link... On the router interface you configure subinterfaces, one per each vlan you need to route, with their proper IP addressing and on each sub interface you would define the same encapsulation type you configured on the trunk link of the switch.
Here's a tutuorial  (1st post attched pdf)
https://learningnetwork.cisco.com/thread/2401
Here's a cisco link (for older equipment, but works the same:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a00800949fd.shtml
Rate helpful posts.
