10-01-2008 10:06 AM - edited 03-06-2019 01:42 AM
I need a cisco L3 switch. The basic functionality i desire is Inter-Vlan Routing. Not much funcitons to be performed by this box. it is only required to do routing between 10 different subnets.
Budget is a constraint.
Please advice
10-01-2008 10:10 AM
You don't say how many ports you need but the 3560 is the entry level L3 switch. See the product page and select the one that meets your port requirements.
http://www.cisco.com/en/US/products/hw/switches/ps5528/index.html
Jon
10-01-2008 10:20 AM
Ya, 24 ports will be ok to me
