02-18-2009 01:01 AM - edited 03-06-2019 04:05 AM
Hi all, when setting up my lan switches, can anyone give me the recommended best practices for setup, ie bpdu guard, broadcast supression etc ?
02-18-2009 02:22 AM
All depends on your network and network policies.
Be carefull when using storm control, if set too high can cause major problems.
Personally, I don't use broadcast surpresion as we invest more heavilly in IDS/IPS and firewall systems.
02-18-2009 08:50 AM
This link is a bit dated but it is still helpful, however you should note to either use bpduguard instead of bpdufilter, or to use only the global portfast bpdufilter command and not use the one that goes directly on the interface.
http://www.cymru.com/gillsr/documents/catalyst-secure-template.htm
02-19-2009 01:41 AM
can you show me what this command for global portfast looks like, how do you make sure its not used on the uplinks in this case ?
