10-11-2016 01:20 PM - edited 03-08-2019 07:46 AM
How to configure switch stack? because I did in the second switch , switch1 renumber 1 then reload and then I'll checked by using show switch the new switch showing is not ready.
Appreciate if someone to tech me In step by step stack configuration.
Thanks & Regards
Julius B.
10-11-2016 01:39 PM
Follow the config guide:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/ha_stack_manager/configuration_guide/b_hastck_3se_3850_cg/b_hastck_3se_3850_cg_chapter_010.html
10-23-2016 03:55 AM
# switch current-stack-member-number renumber new-stack- member-number
example configuration
:# switch 2 renumber 1
Question : what is the current-stack-member-number
: what is the
#reload slot 2 -this is right
Question 2: I will configure this configuration in master? master means the first switch installed? because this is assuming the additional switch.
Then how the configuration of
Please help me this scenario.
THANKS
