SG300 can't enable IP Routing
luisoxirus
Hi everyone, I have an SG300 52 ports PoE but when I'm trying to enable IP ROUTING via CLI, the command down's appear, and by this mean, all the inter-vlan communication is being blocked, do you know what am I doing wrong?
12 Replies 12
You have to change the system mode to router. Go to the command line and type:
Router#set system mode router
Thank you for your answer, it is already done, in fact, was the first thing we did, but still can't reach any VLAN, I can add static routes, but inter-vlan traffic is being blocked, what else could it be? We also upgrade the firmware to the latest version and still doesn't work.
Thank you again, but I also did that already, let me attach my sh run:
config-file-header
CORECA
v1.4.0.88 / R800_NIK_1_4_194_194
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 10-13,40
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
CORECA(config)#set syste
% Unrecognized command
CORECA(config)#
CORECA#set sys
  mode                 Ip Routing support
CORECA#set sys mo
  router               System will run as a IP router
  switch               System will run as a switch
CORECA#set sys mo router
   <CR>
CORECA#ip routing
CORECA#config t
CORECA(config)#ip routing
CORECA(config)#do sh run
config-file-header
CORECA
CLI v1.0
ssd-control-start
ssd config
vlan database
vlan 10-13,40
exit
CORECA(config)#enable
  password             Assign the privileged level password.
CORECA(config)#enable ip
CORECA(config)#ip
  access-list          This command creates an ACL, which perform
                       classification on layer 3 fields and enters ip-access
                       configuration mode.
  arp                  ARP configuration commands
  default-gateway      Specify default gateway
  dhcp                 IP DHCP client commands
  domain               IP Domain Naming System
  helper-address       Specify a destination address for UDP broadcasts
  host                 To define static host name-to-address mapping in the
                       host cache
  http                 Specify the HTTP server configuration
  https                HTTPS server configuration
  igmp                 IGMP interface commands
  name-server          To set the available name servers, use the ip
                       name-server global configuration command.
  route                Establish static routes
  source-guard         IP source-guard configuration
  ssh                  Global Secure Shell protocol configuration subcommands
  ssh-client           secure shell client.
  telnet               Telnet server configuration
CORECA(config)#
CORECA#sh ver
SW version    1.4.0.88 ( date  06-Aug-2014 time  16:55:55 )
Boot version    1.3.5.06 ( date  21-Jul-2013 time  15:12:10 )
HW version    V03
CORECA#sh har
CORECA#sh
  access-lists         Display not empty access control lists (ACLs)
                       configured on the switch
  accounting           Display information accounting
  arp                  Display the entries in the ARP table.
  authentication       Show authentication configuration
  banner               Show the configuration of banners
  bonjour              Shows bonjour advertisement status
  boot                 Shows the status of IP DHCP auto update or auto config
                       process
  bootvar              Show boot attributes
  bridge               Bridging information
  cable-diagnostics    Copper ports diagnostics
  cdp                  CDP information
  class-map            Display QoS class maps, which
                       define the match criteria to classify traffic
  clock                Display the time and date from the system clock
  cpu                  Displays information about the system CPU utilization.
  crypto               Global cryptographic features configuration subcommands
  default-vlan-membership default VLAN membership
  dot1x                802.1x information
  eee                  Energy Efficient Ethernet
  environment          Show system environment information
  errdisable           Show errdisable state.
CORECA#sh ver
HW version    V03
CORECA#sh ver
HW version    V03
CORECA# onfig t
CORECA#config t
CORECA(config)#ip rou=
CORECA(config)#ip rou15-Aug-2014 15:51:11 %AAA-I-DISCONNECT: http connection for user cisco, source 192.168.1.64 destination 192.168.1.1 TERMINATED
15-Aug-2014 15:52:03 %AAA-I-DISCONNECT: http connection for user cisco, source 192.168.1.62 destination 192.168.1.1 TERMINATED
% missing mandatory parameter
CORECA(config)#
CORECA(config)#
CORECA(config)#
CORECA(config)#15-Aug-2014 15:52:20 %HTTP_HTTPS-E-GOHDFIELDSIZE: GOAHEADG: Received illegal length (704) for field (cookie) in HTTP request.
15-Aug-2014 15:52:26 %AAA-W-REJECT: New http connection for user cisco, source 192.168.1.62 destination 192.168.1.1  REJECTED
15-Aug-2014 15:52:32 %AAA-I-CONNECT: New http connection for user cisco, source 192.168.1.62 destination 192.168.1.1 ACCEPTED
CORECA(config)#
CORECA(config)#
CORECA(config)#
CORECA(config)#15-Aug-2014 15:55:06 %COPY-I-FILECPY: Files Copy - source URL HTTP://192.168.1.62/ destination URL flash://image
15-Aug-2014 15:57:06 %COPY-N-TRAP: The copy operation was completed successfully
CORECA(config)#
CORECA(config)#
CORECA(config)#
CORECA(config)#
CORECA#sh run
config-file-header
CORECA
CLI v1.0
ssd-control-start
ssd config
vlan database
vlan 10-13,40
exit
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 192.168.1.101
ip dhcp relay enable
bonjour interface range vlan 1
hostname CORECA
username cisco password encrypted eee3835a2234978e22f8f55c151f558f0c4f7d9e privilege 15
ip ssh server
snmp-server location Mexico
ip domain polling-interval 8
ip telnet server
interface vlan 1
 ip address 10.10.1.10 255.255.255.0
 no ip address dhcp
interface vlan 10
 name Pixel
interface vlan 11
 name PixelTPV
 ip address 192.168.2.1 255.255.255.0
interface vlan 12
 name PixelWebStore
 ip address 192.168.3.1 255.255.255.0
interface vlan 13
 name Clientes
 ip address 192.168.4.1 255.255.255.0
interface vlan 40
 ip address 192.168.15.100 255.255.255.0
interface gigabitethernet1
 switchport mode access
 switchport access vlan 10
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
 description Internet
interface gigabitethernet25
interface gigabitethernet26
interface gigabitethernet27
interface gigabitethernet28
interface gigabitethernet29
interface gigabitethernet30
interface gigabitethernet31
interface gigabitethernet32
interface gigabitethernet33
interface gigabitethernet34
interface gigabitethernet35
interface gigabitethernet36
interface gigabitethernet37
interface gigabitethernet38
interface gigabitethernet39
interface gigabitethernet40
interface gigabitethernet41
interface gigabitethernet42
interface gigabitethernet43
 description AP-1
 switchport trunk allowed vlan add 11-13
 switchport trunk native vlan 10
interface gigabitethernet44
 description AP-2
interface gigabitethernet45
 description AP-3
interface gigabitethernet46
interface gigabitethernet47
interface gigabitethernet48
 switchport trunk allowed vlan add 10-13
interface gigabitethernet49
interface gigabitethernet50
exit
ip default-gateway 192.168.1.254
CORECA#
Attach my sh ver
Can you do a 'sh ip route' and post the output ?
Sure, I attach the out
In the output of 'sh ip route' does it say that IP Forwarding is enabled ? Try to ping your laptop (or whatever is connected to the switch) from the command line:
Switch#ping x.x.x.x
Sure, here the output.
The switch creates default static routes for VLANs automatically only after you plug in a device into the port that belongs to that VLAN. So if you want to communicate between let's say VLAN 10 and VLAN 13, you need to first plug a device into the ports on your switch that are assigned to VLAN 10 and 13 respectively.
Yes, right now there are no ports on the other VLANS, but when the switch was on a productional environment there was ports on the other VLANS and the result was the traffic inter-vlan blocked, and still ip routing command, was unable to set it.
Any ideas? Maybe the software version, of the model, what else should I try?
at this point, I would reset the entire switch and start from scratch. The 'ip routing' command is not available on the SG300. By setting the system mode to router, ip routing is automatically enabled.
So, my suggestion is:
CORECA(config)#set system mode switch
This will reload the switch and delete the startup configuration. Once the switch comes back up, set the system mode to router:
CORECA(config)#set system mode router
This will reload the switch again, when it comes back up, ip routing is enable. Then create your VLANs etc.
Take a look at this thread, the user had the same problem.
https://supportforums.cisco.com/discussion/13067106/inter-vlan-routing-cisco-sg300
