Switch Stack Question
dacruzer1
Can I stack a 3750G over a 3750X or vice versa?
Alfred
6 Replies 6
Alvaro Garcia
Yes, you can. There is no problem stacking different models of 3750 switches. I would suggest to make sure they all are running the same IOS version and feature set.
Thanks much!
hobbe
Level 7
Level 7
Yes you can *(unless the 3750x is a LAN base they can only stack with other lanbase)
but you will loose some funktionality and speed when mixing stacks.
good luck
Thanks much!
Some additional info:
Q. Are mixed stacks supported?
A. It depends. The Cisco StackWise and  StackWise Plus solutions are flexible enough to allow you to:
• Stack any Cisco Catalyst 3000 switch in the same stack (hardware mixed  stack)
• Stack any Cisco IOS Software feature set in the same stack (software  mixed stack)
One exception is the new LAN Base models being introduced with the Catalyst  3750-X and 3560-X Series, which can stack only with other LAN Base models.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-578933.html
They are all IP Base, which should not ne problem.
Alfred
