Switch that restarts without stopping
Translator
Community Manager
Community Manager
Hello everyone,
I have a managed SG350-10P POE switch.
I connected my orange box to the swtich port 1.
My problem: the switch constantly reboots. I can't access the switch via the web interface because since it reboots and loses connection.
How can I stop the switch from rebooting every 2 minutes?
Thank you for your help...
Mark Elsen
 - Check logs if still possible or configure a syslog server, if not consider factory reset and configure the device again.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
if you can manage to get to the console, post any output you see. There is also is a bug (pasted below), the only workaround is an RMA...
Sx350/550 -HAL_config_poe-F-POEInitError: HALP_config_poe_692xx_check_master_reset: ...
CSCvk62334
Customer Visible
Notifications
Save Bug
Open Support Case
Description
Symptom:
switch not accessible
Conditions:
fatal error in logs
HAL_config_poe-F-POEInitError: HALP_config_poe_692xx_check_master_reset: HALP_config_poe_number_of_poe_devices is Zero: Failed on init.
***** FATAL ERROR *****
Reporting Task: HCPT.
Software Version: 2.3.0.130 (date May 10 2017 time 01:07:22)
ros(HOSTG_fatal_error 0x14) [0x29e9b4]
ros(OSSYSG_fatal_error 0x134) [0x7f80d0]
ros() [0x624144]
ros(HALP_config_poe_692xx_dev_op_set_periodic 0xa84) [0xb16d64]
ros() [0xb09cf8]
ros(HALP_config_poe_691xx_692xx_poe_dev_operation 0x48) [0xb09ddc]
ros(HALC_config_poe_dev_operation 0x44) [0xb1af3c]
ros() [0xabd8dc]
ros(HALC_config_device_dispatch 0x1a4) [0xabe9bc]
ros() [0xad76f0]
ros() [0xad78fc]
ros() [0xad7968]
/lib/libp2linux.so.1( 0x3aa4) [0xb6f36aa4]
/lib/libpthread.so.0( 0x6e64) [0xb6f11e64]
***** END OF FATAL ERROR *****
Workaround:
RMA
Further Problem Description:
PoE error
