Switch Trunk Port
heusmannbm
I have 2 3750G switches with a trunk configured, CORESW01 gi1/0/48 trunk, CORESW02 gi1/0/1 trunk. I purchased 2 SFP connectors for ports gi1/0/49 to create a new trunk. Is the best way to migrate to this is setup a trunk on ports gi1/0/49, connect the ports and then disconnect the existing copper? Thanks.
-BH
Mark Malone
remember if you create 2 trunk links that are not bundled together of equal cost  between 2 switches at the same time stp will block 1 to prevent a loop
you could configure the new sfp trunk keep it shut down , put a high stp cost on the current only trunk link as traffic will still pass , then bring up your new trunk with a lower cost it will take over
or
build them into and etherchannel and then remove the old link
There probably the least service effecting i can think off without shutting down you current link
