Switch will not talk to router
mikerocom1
I have a Cisco 2851 and a 3750. At one point everything was fine and everything was working. I was able to access the internet from multiple vlans. Now for some reason, which i cant figure out, my switch will not ping my router. I cannot access the internet.
I have a cable modem which is DHCP, static IP is not an option. Modem>Router>Switch>Computers
My goal is
Vlan 10 for my internet acces
Vlan 20 for guest wifi
Vlan 30 for IP cameras
Router config:
Current configuration : 1810 bytes
version 12.4
hostname mikerorouter
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging console
enable secret 5 $1$WC5M$b2bgySF8XI.MqeufJzi2O/
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.10.17.1
ip dhcp excluded-address 10.10.17.2
ip dhcp excluded-address 10.10.17.3
ip dhcp excluded-address 10.10.17.4
ip dhcp excluded-address 10.10.17.5
ip dhcp pool mikero
   import all
   network 10.10.17.0 255.255.255.0
   default-router 10.10.17.1
   dns-server 68.105.28.12 68.105.29.12 68.105.28.11
ip domain name mikero.com
no ipv6 cef
voice-card 0
username admin secret 5 $1$snHZ$/D6wf/iVK7ii6js.RloA80
archive
 log config
  hidekeys
ip ssh version 2
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN
 no ip address
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 10.10.17.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
no ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
access-list 101 permit ip 10.10.17.0 0.0.0.255 any
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
line con 0
line aux 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
scheduler allocate 20000 1000
end
Switch Config:
Current configuration : 3743 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname mikeroswitch
no logging console
enable secret 5 $1$q48p$GHvmx5zju53WBx/7UncGD.
username admin secret 5 $1$2dnq$aA2/XzzIatORrobHFoYzc0
no aaa new-model
switch 1 provision ws-c3750-48p
ip subnet-zero
ip domain-name mikero.com
ip ssh version 2
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
 shutdown
interface FastEthernet1/0/2
 description DESKTOP MIKERO
 switchport access vlan 10
 switchport mode access
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
 shutdown
interface FastEthernet1/0/18
 shutdown
interface FastEthernet1/0/19
 shutdown
interface FastEthernet1/0/20
 shutdown
interface FastEthernet1/0/21
 shutdown
interface FastEthernet1/0/22
 shutdown
interface FastEthernet1/0/23
 shutdown
interface FastEthernet1/0/24
 shutdown
interface FastEthernet1/0/25
 shutdown
interface FastEthernet1/0/26
 shutdown
interface FastEthernet1/0/27
 shutdown
interface FastEthernet1/0/28
 shutdown
interface FastEthernet1/0/29
 shutdown
interface FastEthernet1/0/30
 shutdown
interface FastEthernet1/0/31
 shutdown
interface FastEthernet1/0/32
 shutdown
interface FastEthernet1/0/33
 shutdown
interface FastEthernet1/0/34
 shutdown
interface FastEthernet1/0/35
 shutdown
interface FastEthernet1/0/36
 shutdown
interface FastEthernet1/0/37
 shutdown
interface FastEthernet1/0/38
 shutdown
interface FastEthernet1/0/39
 shutdown
interface FastEthernet1/0/40
 shutdown
interface FastEthernet1/0/41
 shutdown
interface FastEthernet1/0/42
 shutdown
interface FastEthernet1/0/43
 shutdown
interface FastEthernet1/0/44
 shutdown
interface FastEthernet1/0/45
 shutdown
interface FastEthernet1/0/46
 shutdown
interface FastEthernet1/0/47
 shutdown
interface FastEthernet1/0/48
 shutdown
interface GigabitEthernet1/0/1
 description UPLINK
 switchport mode trunk
interface GigabitEthernet1/0/2
 shutdown
interface GigabitEthernet1/0/3
 description WAP
interface GigabitEthernet1/0/4
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 description MIKERO
 ip address 10.10.17.2 255.255.255.0
ip classless
ip http server
control-plane
line con 0
 speed 115200
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
16 Replies 16
Actually, that did work.
Thank you!
Glad that worked.
Please rate and mark the post as answered, so others can benefit from it.
