Switch
vaishkhan161190
Frequent Visitor
Frequent Visitor
anybody can tell me that the use of  spanning-tree Command.
where we configure spanning tree on Router or switch?
Thanks & Regards
Hossein Ansari
Community Member
Dear vaishkhan161190,
if you want to prevent loop in your switch network u can use spanning tree protocol. spanning tree is a mechanism that will prevent from infinite loop of  packets.it is a Layer 2 protocol so no need to run on routers because routers are L3.
pls read the folloing like
http://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/5234-5.html
I hope it was Informative .
Hossein
Hossein Ansari
Community Member
Hossein
vaishkhan161190
Frequent Visitor
Frequent Visitor
Thamks Mr. Hossein
Thanks & Regards
